evlength question
when I select several lines evlength add the total length and extrude.
How to keep each extrude the same length as the sketch line but able to still select multiple line.
Jake_Rosenfeld Moderator, Onshape Employees, Developers Posts: 1,646
You can use 'evaluateQuery(...)' to get all the lines as individual queries, and then use a for loop over the lines:const lines = evaluateQuery(context, lineQuery); for (var line in lines) { const lineLength = evLength(context, { "entities" : line }); // extrude(...) or opExtrude(...) using lineLength }
Jake Rosenfeld - Modeling Team5
