Learning Center Support
KatieHuffman
                    Member, Onshape Employees, Developers Posts: 194
                    Use this category to get help with exercises in the Learning Center, request improvements to enhance your learning experience, and report outdated material. If you are having trouble with an exercise, please provide the course, exercise title, and description of the issue.
The preview image for this course: https://learn.onshape.com/courses/fundamentals-navigating-onshape
is outdated
Hi katiehuffman, i finished the Onshape fundamentals of data management in some past day, I am waiting you release the certificate, but I have seen any releasing for its certificate.
Have you completed the survey at the end of the course?
Don't know if I'm missing something: I'm trying to find the Assembly Documents to follow along in this Learning Center course
https://learn.onshape.com/learn/course/fundamentals-onshape-assemblies/mating-assembly-components/onshape-mate-types
Could you please assist?
Roll to #2 Sketch: 5.072, Roll to #3 Sketch: 0.896, Roll to #4 Sketch: 1.192, Roll to #5 Sketch: 1.257, Roll to #6 Sketch: 1.418, Roll to #7 Sketch: 1.416, Roll to END: 1.403
How can I create that section view?
Thanks.
Please look at the section titled View parts sectioned with Section view here: https://cad.onshape.com/help/#moving.htm
and if you need to move it, you can use the manipulators
https://learn.onshape.com/learn/course/fundamentals-sketching/sketch-constraints/dimensions
https://forum.onshape.com/discussion/comment/38545#Comment_38545
We do have a college curriculum that you can reference and use for your class.
Thanks!
https://learn.onshape.com/learn/course/fundamentals-part-design-using-part-studios/creating-draft-shell-and-rib-features/exercise-step?page=2
It is a excise on creating Draft, Shell and rib features(create a step), I have difficulty recreating Slide 15/30
My work is located here:
https://cad.onshape.com/documents/1b7257a912b905482976f51a/w/c3e2320d9c1e6f4ea5d06847/e/0965c0bbf9889fd381379dc1
Would you please give me some guidance where I made mistakes? I have tried to remake this object twice stuck on the same step.
Thanks!
Sorry you're having difficulties!
On slide 14 it says that you should be making your sketch on the "Right plane". Your sketch is on a face of your part, whereas the instructions are trying to tell you to place the sketch on the "Right" default plane. When sketched correctly this looks like:
I was going through the exercise and didn't run into any problems but appreciate you taking the time to spot the error.
https://learn.onshape.com/learn/course/managed-in-context-design/what-is-managed-in-context-design/exercise-step-stool-creating-contexts?page=2
When selecting the hole that that shares the sketch plane to use the edge in my sketch OnShape tells me that it could not project the selected entities into the current sketch. I can use the edge of the other hole on the other step with not problems. i was able to select the edge of the hole that wasn't on the sketch plane though.
I am very new to using any cad type program. I am currently doing the parts design using the parts studio course and I cannot seem to get the rim to extrude, on slide 19. Any ideas on what i may be doing wrong??
Thanks Spencer
does this work? how do i do a screen shot??ha
If you hover over feature name, a tool tip would tell you more.
it looks like you have the incorrect sketch profile selected to cut with. Remember you are just using the outside-most profile of the main sketch to extrude remove.
