Openbom
brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
Can anyone say how to insert the openbom BOM in the drawing now. I have been trying for some time now but only seem to be able to get the onshape simultaneous BOM. a little help would be appreciated thank you.
Regards Brian.
  • mthiesmeyermthiesmeyer Onshape Employees Posts: 115
    Hi Brian,
    If you have inserted an Assembly view the Insert BOM dialog will auto-populate with a reference to that assembly. If you would like to place a BOM from Open BOM, Onshape BOM for Google Sheets, or another assembly you can select the Insert icon next to the list of references in the Insert BOM dialog.
    Best,
    Mike
  • brian_pinder662brian_pinder662 Member Posts: 119 ✭✭
    Thank you very much for your help, All the best Brian
