FeatureScript request -- Wood joinery
RyanAvery
Member Posts: 93 EDU
There is already a good lap joint FS
and a pretty decent box/finger joint FS.
There is however no FS for bridle joint or miter joint or butt joint with 1x 3/8th inch dowel that is 1.5" long, etc. There is a lot of room for a bunch of useful FS's I think that have to do with woodworking joinery.
2
anyone?0
2
@RyanAvery
I have made a FS to make a butt joint with a pin.
It currently doesn't work very well for obtuse corners, but works alright for acute corners and right angles
https://cad.onshape.com/documents/deaa950158a21eba4f7b2cda
EDIT: It now works with obtuse corners1 -
Oh wow. Yeah it is hard to find these FS from the search place.0
@RyanAvery
If you want a full list of FeatureScripts, go to https://github.com/dcowden/featurescript0 -
Why have I not heard about this???mbartlett21 said:@RyanAvery
Thanks for the link1
You didn't do your homework by reading through every discussion in this forumRyanAvery said:
//rami1 -
For dowel FS you should have option to only create holes and use assembly replicate to populate them, otherwise your BOM will be pretty long with separate line for each dowel..
//rami1 -
That's a good idea.0
@3dcad3dcad said:For dowel FS you should have option to only create holes and use assembly replicate to populate them, otherwise your BOM will be pretty long with separate line for each dowel..
@RyanAvery
Done!
New version V1.20
