"Create and transform assembly instances" post request example
connor_holjesconnor_holjes Member Posts: 9 PRO
Can anyone post an example of the body for this? Just looking to insert a part into an assembly with some given translation and rotation...
  • connor_holjesconnor_holjes Member Posts: 9 PRO
    Made some progress, was able to get the partId inserted into the assembly, looks like at the origin. If I try and do a translation though I get this error:
        "moreInfoUrl": "",
        "message": "Provided transform matrix is not a rigid rotation.",
        "status": 400,
        "code": 9999
    Okay more progress... so I am using the 4x4 translation matrix but I get the same error as before if I try and do a reflection...?
       "transform": [
          -1,0,0,0,
          0,1,0,0,
          0,0,1,0,
          0,0,0,1
    Okay! Another question. How Can I specify the configuration. Does not seem to be changing the part?
       "transformGroups": [{
       "transform": [0, -1, 0, 2, 1, 0, 0, 2, 0, 0, 1, 0, 0, 0, 0, 1],
       "instances": [{
          "partId": "XXX",
          "configuration": "24",
          "documentId": "asdjsdu0a9doasnasdasdas",
          "elementId": "aasoidua332asdsdasda"
    "microversionId": ""
    "24" is the name of my configuration but it keeps inserting the "Default"
    Very helpful thank you! Just to clarify, is the configurationencodings API 'encoding' anything or is it just concatenating the parmaId and the paramVal? Just want to avoid making another request if that is all that is happening.
  • mark_noyesmark_noyes Member, Onshape Employees, Developers Posts: 21 image
    In many cases it is simple and you could easily form the configuration string yourself, as you suspect. With multiple inputs the inputs also need a ';' separator. Things get trickier if the values contain any non-alpha-numeric characters and there is some additional encoding that gets done. Therefore, we do recommend that you use the API to avoid surprises.
