How do I do mate connection for 90deg gear in assembler
RyanAvery
Member Posts: 93 EDU
How do I do the mate connector for this? I have 2x 45degree angled gears and I want them to rotate eachother.
Anyone know how to make this gear relationship? When I try the mate connectors it doesn't line up perfectly.
So sorry, been at work for 11hours so far am a bit fried, please give it another go.
HWM-Water Ltd5 -
Sure thing
HWM-Water Ltd5
Use 2 revolute mates to get the rotation in the directions as shown. Then link them with the gear mate at the desired ratio. Gear mate is really just a way to link the existing revolute mates via a ratio and rotation direction.1
When I do that the gears move to be end to end as if it is one large gear instead of 2, one on top of the other.0
If you post a link to your document I'm sure somebody will sort it out for you
HWM-Water Ltd1 -
Philip Thomas - Onshape1 -
HWM-Water Ltd0 -
https://cad.onshape.com/documents/cb0d31c8ba2be4f0f4f7a473/w/89e55966149663d6912f825e/e/71ccc386bbc72853442b0106
I would like to have the gears be at right angles to each other. The gears are twisted at 45 degrees so I think it should work.
I'm comp sci not engineering so I'm not sure how it all works at the moment.0 -
I'd like to know how to do it not just have it done for me though!0
Working on it...
HWM-Water Ltd0 -
OK.
First stab at it here.
Take3
https://cad.onshape.com/documents/93f5d20d6703cafeda99e0cf/w/51f8bd2bf7a63edbef6033ad/e/fbc877d30a05748467e19fea
As for the knowing how to do it that's the great thing about parametric cad, you can use the roll back bar in the part studio to step through what was done.
We need to treat each part individually and then make them move together.
Steps.
(1) To make the handle or shaft spin we use revolute mates. They need something to mate to so I've made a rudimentary base but anything will do.
(2) Once we have the base I've put mate connectors in appropriate places (all still in the part studio.)
(3) Then we go to the assembly and make the revolutes.
(4) Once they work OK we add a gear relation between them.
If we look at the assembly in cross-section we can see they don't quite mesh. This can be fixed with by rotating one of the mates to suit back in the part studio:-
I've left that step, and mating the secondary
shaft for you
Hope that helps, if not please shout.
Cheers,
HWM-Water Ltd0 -
I get this message when I click your link:
Failed to load document for workspace. Resource does not exist, or you do not have permission to access it.
That's because I'm an idiot. Hang on a minute.
HWM-Water Ltd1 -
Document is erm, ah, public now
Please try it again.
Ta,
HWM-Water Ltd0 -
Link doesn't work now0
Thanks for the help though0
HWM-Water Ltd5 -
Works great, thanks a lot! I will try to understand how you did it now.
Thanks for the help0 -
Sure thing
HWM-Water Ltd5 -
Dude, that's less than half a day..owen_sparks said:So sorry, been at work for 11hours so far am a bit fried, please give it another go.
//rami2 -
You're not wrong, but I'm not self employed...
...also there's no food here!
HWM-Water Ltd0 -
Rami - I have seen Owens desk - also there's no food and the coffee sucks!
If there are no photographs it never happened, but he's right about the coffee, I wouldn't even insult an American resident by offering it to them!
O.S.
HWM-Water Ltd0 -
We're good at sheep though, and more importantly beer.
HWM-Water Ltd1 -
So you wen't home to have a beer and kebab - that is acceptable if you hang in Onshape forums at least few more hours to call it a day.//rami1
