Round surfaces are displayed as lines in the DXF (bending)
hobie_smith
Member Posts: 35 ✭✭
Hello,
why edges of a folded bent part are not displayed round but as lines in the DXF.
I attach an example file.
Am I making any mistake?
lana
Onshape Employees Posts: 761
The curve you are referring to is not an arc. In 3D it is an intersection if two cylinders and it does not unroll into arc in flat either. If you make a drawing that curve should be represented as a spline, we are working to preserve spline representation in direct DXW/DWG export as well.5
