Importing a text file of x y z points
eoin_cannoneoin_cannon Member Posts: 1
Hi
I can't find an answer here but does anyone know if it's possible to import a txt file of x y z points. Does OnShape have a different file format or anything? Solidworks uses .sldcrv which is just a renamed .txt file in a certain format. I've attached the file I want to import.
Any help would be greatly appreciated.
Thanks
Eoin
  • andrew_troupandrew_troup Member, Mentor Posts: 1,584 ✭✭✭✭✭
    No such capability exists yet in Onshape.
  • steven_chandrasteven_chandra Member Posts: 1
    Hi, I'm just wondering if there are any news regarding importing X Y Z co-ordinates. This question was asked in August, wondering if they have added anything new since then that can support this.
    edited January 2016
    @steven_chandra
    Still the same.
  • eric_laueric_lau Member Posts: 17 ✭✭
    Anything new here?
  • 3dcad3dcad Member, OS Professional, Mentor Posts: 2,470 PRO
    These days it's best to create improvement request for voting. Choose IR gategory on right and create new if this doesn't exist already..
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,175
    There's no way to do it directly, but it is possible to upload a CSV file of XYZ data and create a custom feature that turns it back into points.  Let me know if this is interesting and I'll post an example.
  • emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 859 ✭✭✭✭✭
    You should check this FeatureScript: 3D Points
    It allow you to import the X,Y, Z list of points as points or create splines or polylines
    Un saludo,
    Well - this one has been up for a while!
    Super simple - reads an XYZ CSV file and passes a 3D spline through it.
    https://cad.onshape.com/documents/f8191d0fd7fe9a488e8dcd15/w/29be675d29fa9f017b6fed6e/e/2de5c3146b997f177a4bd4e5
    Here is the source code - super simple :)
            var points = [];
            for (var row in curveData)
                points = append(points, vector(row[0], row[1], row[2]) * meter);
            opFitSpline(context, id, {
                        "points" : points
    Have fun! :)
    Philip Thomas - Onshape
    @philip_thomas
    I would like to see the code of your 'BOOM'-image creator that adds those images to your posts.  :D
