Importing a text file of x y z points
eoin_cannon
Member Posts: 1 ✭
Hi
I can't find an answer here but does anyone know if it's possible to import a txt file of x y z points. Does OnShape have a different file format or anything? Solidworks uses .sldcrv which is just a renamed .txt file in a certain format. I've attached the file I want to import.
Any help would be greatly appreciated.
Thanks
Eoin
Thanks
Eoin
No such capability exists yet in Onshape.0
Hi, I'm just wondering if there are any news regarding importing X Y Z co-ordinates. This question was asked in August, wondering if they have added anything new since then that can support this.0
Anything new here?0
These days it's best to create improvement request for voting. Choose IR gategory on right and create new if this doesn't exist already..
//rami0 -
There's no way to do it directly, but it is possible to upload a CSV file of XYZ data and create a custom feature that turns it back into points. Let me know if this is interesting and I'll post an example.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
You should check this FeatureScript: 3D Points
It allow you to import the X,Y, Z list of points as points or create splines or polylinesUn saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común1 -
Well - this one has been up for a while!
Super simple - reads an XYZ CSV file and passes a 3D spline through it.
https://cad.onshape.com/documents/f8191d0fd7fe9a488e8dcd15/w/29be675d29fa9f017b6fed6e/e/2de5c3146b997f177a4bd4e5
Here is the source code - super simple
var points = [];for (var row in curveData)points = append(points, vector(row[0], row[1], row[2]) * meter);opFitSpline(context, id, {"points" : points});
Have fun!
Philip Thomas - Onshape0 -
@philip_thomas
I would like to see the code of your 'BOOM'-image creator that adds those images to your posts.
//rami1 -
I've seen a version of your importer that allows CSV import containing multiple splines:
Is that an official Onshape release?
looks like this is the one:
It's really hard to navigate the featurescript search and find the original version, there are so many copies! Is there a trick to search for it?
