Measure distance between two points along a spline
tosch_roytosch_roy Member Posts: 2
I'm wondering if there's a way to set two points on a spline and then measure the distance between these two points, along the spline, not the minimum distance (which is what shows up automatically in the measurements bar). Any thoughts?
