Measure distance between two points along a spline
tosch_roy
Member Posts: 2 ✭
I'm wondering if there's a way to set two points on a spline and then measure the distance between these two points, along the spline, not the minimum distance (which is what shows up automatically in the measurements bar). Any thoughts?
OptionsemagdalenaC2i Member, Developers, Channel partner Posts: 861 ✭✭✭✭✭You can split the spline in 1 or 2 point and selec the spline. In the bottom right you can see the length of that spline
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común2
