Sheet Metal - Two flanges on one edge
Hello,
Can someone help me as I get the second flange down on that edge.
I've tried everything I can, but it does not work.
Greetings Hobie
https://cad.onshape.com/documents/cd039f8ab6a25a136df19cbe/w/2d2970700fc998929181da4e/e/360f4f27b7656e25c62c0b3f
emagdalenaC2i Member, Developers, Channel partner Posts: 863 ✭✭✭✭✭
You can create a mirror of the faces of the first flange
https://cad.onshape.com/documents/c2f210deac0a53062cffddb1/w/39f06a454a0f312fb5ce51e2/e/a418fc03c9ced33644fd8325
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común2 -
lana Onshape Employees Posts: 743
Or you could cut your flange in the middle: https://cad.onshape.com/documents/540f9c65b9276673bc821e1d/w/4a056aafea836465b290cc1c/e/6e9a9d2e0237df8889d5a3ea1
