Applying Material in featurescript
Can somebody point me to the right direction on how I can do this.
I have a material in FS as enum . but no density , no color etc yet.
and I know onshape has a material .
But can I add a material properties that I can apply to a body in FS?.
kevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565
Materials set by FS are currently not the same as the materials in your material library. You set identical material name and a density (which is the same info as materials in the your library), but that info will not directly reference the library.
If you'd like this to change, please vote on the improvement request here.5
