Unfold or flatten surface?
gaëtan_bussy
Member Posts: 3 ✭
Hello,
I made a skateboard design in onshape.
The skateboard will be made by seven sheets of wood. I want to cut those sheets by laser.
To be precise, we have to flatten the surface. I tried the FS "fold" (unfold) but this FS made only a projection and not a realy unfold or flatten function.
How can we do a real unfold function in a surface?
Thanks!
PS the project: https://cad.onshape.com/documents/e6ce8a9d2d64fc49dd2d8727/w/3b7be7a9979035a1a31f1dfa/e/66b7d6dfbea81de149d87b97
Thanks!
But I only managed to made a simple projection...
Thanks! Yes I already made one test. It's quite good! I had some problems with the unities in the file exported. I have to make more tests.
But if the solution is not in an external module, it would be great! I want to orgenise workshop about creating skateboard with young people... the simplest would be the best!
And this is not a long term free solution...
So... I have to find something else...!
https://extensions.sketchup.com/en/content/flatten-faces
Rhino also has a decent flatten command. You can get a 90-day free trial.
thanks Pascoe!
https://cad.onshape.com/documents/8b05b9839aba12bb8ccb2b7e/v/09003b9bc2cb1ae185dd2aa4/e/dda6fda206e5409a01f69cee?showReturnToWorkspaceLink=true
https://cad.onshape.com/documents/12312312345abcabcabcdeff/w/a855e4161c814f2e9ab3698a/e/5e639eb1b1834188ae46203a
