Restore Sketch
s_d665
Member Posts: 5 ✭
I just spent an hour working on a sketch and accidentally hit the X instead of saving it. The restore bubble popped up, but I was unaware it was only there for 10 seconds, and it disappeared before I could click it. And now I'm extremely irritated. Is there any other way to restore a sketch? If not, I recommend leaving that popup there permanently until it is physically x-ed out by the user.
I think that you should create sketches as simple as you can, and as many as you need instead of a single big sketch
