Can't Sketch on Extruded Surface
bradley_bickfordbradley_bickford Member Posts: 2 EDU
Obligatory Link: https://cad.onshape.com/documents/6d03383d255b1893e0fb05a8/w/9f545045c1ecf2d73af64327/e/077d9cf30cd831958aa36c2e
I can't for the life of me figure out what I'm doing wrong. I've made this part here and the extrusion that doesn't have any holes in it right now I'm trying to make a sketch surface on it, every time I make a sketch on the surface, it doesn't let me use any of the sketching tools. I've even tried making a plane against that surface and it still doesn't work. Have I done something the wrong way around? I can't seem to figure this out.
    Hi @bradley_bickford
    It seems like I can sketch on all the planes here.  Could you describe in more detail, or better yet post a screenshot, of the face you are having trouble sketching on?
  • bradley_bickfordbradley_bickford Member Posts: 2 EDU
    I just tried sketching again myself, and it's working! For some reason! It's possible that tab had a memory overrun that was causing a problem. (Chrome being difficult, in other words).
    Good to hear! Sorry you had troubles.  Please let us know if it happens again!
