cut with surface
In SW there's a 'cut-with-surface' tool. I can't see that functionality in Onshape but perhaps I'm missing something. I can see there's the split command. However, I believe with that command I split and then delete body. Am I missing something? I'm trying to cut a part/body with a plane (or surface). I think this could be provided as an option within the split command but it doesn't seem to be there.
All thoughts/suggestions gratefully received...
If you would like this functionality implemented, please make an improvement request in the category at the right --->
CurrentlyYou have to use the split command, then delete body.
https://cad.onshape.com/documents/2a9478fb3b342d43b25073c9/w/4e2acd5778a26dff3e3c3bdc/e/aca26ef062814ab900c893af
