Implementing Snell's Law in a sketch
mac_frolic077
Member Posts: 2 ✭
Hi
I wonder if there is a way to define a constraint between lines that represent the law of refraction?
i.e. I have a line with a point that represents the border of two mediums (air and glass). I want to draw a line that represents a ray of light that hits the surface in a certain angle. and I want to draw a line that represents the ray refracted inside the medium.
something like this:
https://www.geogebra.org/m/WnaEUHzW
I also want to be able to extend it to see how the refraction of a prism would influence the path of a ray.
in terms of the above example (after the link) angle phi is a function of angle alpha and the refraction-index of the two materials.
so what I am looking for is a constraint that can be defined by a function.
I know there is featurescript, but I have no experience with it. if this scripting language can help me with this problem, I would be glad if somebody can point me in the right direction, i.e. a script that can do something similar.
cheers
martin
cheers
martin
https://cad.onshape.com/documents/258a19506c555f400614c944/w/74e657ae2800105e2874589a/e/71d75b30fc9a22f4a9b82a08
TVP, Onshape Labs
https://cad.onshape.com/documents/109847f3ca92fbe0b164942e/w/07c893ecde8849e9ad780149/e/62ff57faac476c02966bed8f
