bend notes text size
papawopapawo Member, Developers Posts: 206 PRO
is there a way to change the size of the text of the bend notes of flat sheet drawing
  • papawopapawo Member, Developers Posts: 206 PRO
    found the solution...
    upper left area of the drawing , click the wrench , it will open up a properties window. and there is a text size box that can be modified.
