Shift # = left view
dave_schrat
Member Posts: 19 ✭✭
After drawing something in a sketch the box appears to enter the dimension. I want to enter my variable #Sl. So I hold Shift and when I hit # the camera switches to Left View. Keyboard short cut for Left view is Shift 3 (same button as #). I assume Onshape is looking for a number and thus ignores the Shift???? But recognizes it enough to flip the view???? I have to skip the dimension and later go back to enter the variable, which annoying but not as bad as when I forget and the whole the view flips. Is there a work around or am I missing something?
robert_morris
OS Professional, Developers Posts: 173 PRO
You can hit the '=' key first, then you should be able to enter in your variable.7
