PATTERN_NOT_ON_BODY
papawo
Member, Developers Posts: 206 PRO
Jake_Rosenfeld
This is an error that face pattern gives if the transformations applied to the selected faces don't result in those faces landing on the body that they originate from. It would be easier to debug the issue that you are seeing if you provided a document with an example of the issue.Jake Rosenfeld - Modeling Team6
