Linear sketch pattern -default 25 mm pattern step - how to change this default?
gianmario_scotti
Member Posts: 22 EDU
Dear all,
using the Onshape Linear SKETCH Pattern tool has been frustrating: the main annoyance is OnShape's default value of 25 mm. In my current case, this puts the manipulators way outside of my working area. Can this default be changed?
Thanks in advance!
Thanks in advance!
emagdalenaC2i
Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
There is no option to change the default values in Onshape.
But, usually is it better to create the array of a feature instead of inside of a sketch.
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común6
