Can we use FS to set the "Exclude from BOM" property.
owen_sparks
Member, Developers Posts: 2,660 PRO
Hi folks.
I have a part studio that uses configurations to create a laminated material.
I have the configuration table set a sensible PN and name description for just the first layer of the laminate but I'd like to exclude all the other layers from the BOM. Rather than set many values in a table for each config option I thought I'd use FS to set the exclude from BOM property.
setProperty(context, {<br> "entities" : definition.bodies,<br> "propertyType" : PropertyType.Exclude from BOM,The auto complete doesn't seem to show such a setting, so my Q is "is this property exposed to FS?".
Thanks for your time,
NeilCooke
Moderator, Onshape Employees Posts: 5,992
Hi @owen_sparks - in short, no, though I don't see why not?
Here is the enum:export enum PropertyType { NAME, MATERIAL, APPEARANCE, DESCRIPTION, PART_NUMBER, VENDOR, PROJECT, PRODUCT_LINE, TITLE_1, TITLE_2, TITLE_3, CUSTOM }Senior Director, Technical Services, EMEA5 -
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,255
That's fine, I think it's simple enough that I'll just add it (not next release, but "coming soon").Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc1 -
ilya_baran
This should be available as of the update we pushed yesterday (make sure you use the latest version of std).Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc2 -
owen_sparks
Thanks again, 60 seconds of featurescript and I now have BOMs in "sensible mode".
Happy Onshaper here.Cheers,Owen S.Business Systems and Configuration Controller
HWM-Water Ltd3
Here is the enum:
export enum PropertyType { NAME, MATERIAL, APPEARANCE, DESCRIPTION, PART_NUMBER, VENDOR, PROJECT, PRODUCT_LINE, TITLE_1, TITLE_2, TITLE_3, CUSTOM }HWM-Water Ltd
I think the best looming may actually be creating an IR for this.
Cheers, Owen S.
Have a good weekend, Cheers Owen S.
Cheers,
