Can we use FS to set the "Exclude from BOM" property.
owen_sparks
Hi folks.
I have a part studio that uses configurations to create a laminated material.
I have the configuration table set a sensible PN and name description for just the first layer of the laminate but I'd like to exclude all the other layers from the BOM.  Rather than set many values in a table for each config option I thought I'd use FS to set the exclude from BOM property.
setProperty(context, {<br>                    "entities" : definition.bodies,<br>                    "propertyType" : PropertyType.Exclude from BOM,
The auto complete doesn't seem to show such a setting, so my Q is  "is this property exposed to FS?".
Thanks for your time,
Owen S.
HWM-Water Ltd
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,278 image
    That's fine, I think it's simple enough that I'll just add it (not next release, but "coming soon").
  • ilya_baran
    This should be available as of the update we pushed yesterday (make sure you use the latest version of std).
  • owen_sparks
    Thanks again, 60 seconds of featurescript and I now have BOMs in "sensible mode".
    Happy Onshaper here.
    Cheers,
    Owen S.
    HWM-Water Ltd
  • owen_sparks
    edited May 2018
    Thanks Neil.
    Is there anyone's desk that I can bribe you to loom over to make it happen? :p (As a future release, please don't go to any trouble today.)
    Cheers,
    Owen S.
    HWM-Water Ltd
  • Jake_Rosenfeld
    @owen_sparks
    I think the best looming may actually be creating an IR for this.
  • owen_sparks
    Thanks Jake, that I can do.
    Cheers, Owen S.
    HWM-Water Ltd
  • ilya_baran
  • owen_sparks
    Excellent, thanks for that, much obliged.
    Have a good weekend, Cheers Owen S.
    HWM-Water Ltd
  • ilya_baran
  • owen_sparks
    Outstanding, thank you @ilya_baran, I'll make good use of it on Monday.
    Cheers,
    Owen S.
    HWM-Water Ltd
  • owen_sparks
    Cheers,
    Owen S.
    HWM-Water Ltd
