Colors in Featurescript
Hey Onshape people-
I'm working on a project for competitive robotics and it would be pretty sweet if I could set the color of a part/extrude in featurescript. The standard documentation doesn't seem to have functionality for it and a quick search didn't turn up anything, but any help that you can provide would be much appreciated!
I'm new to the forums so sorry if I missed anything big or didn't catch a previous answer to this question.
Any chance Onshape is looking for interns?
Philadelphia User Group Leader
I've even looked over if there is something about it in the vanilla forums, which I think is the one used here... but without results
This is possible through the new `setProperty(...)` call:
https://cad.onshape.com/FsDoc/library.html#setProperty-Context-map
D'oh! Thanks
There is currently no way to change the color of an edge in Onshape (in FeatureScript or from the UI). If you would like to see this functionality implemented please add an improvement request on the Improvement Requests section of this forum.
Something that may be helpful in the meantime:
https://cad.onshape.com/FsDoc/library.html#debug-Context-
If you call `debug(context, edgeQuery)` in FeatureScript it will turn the edge red. The red will only appear when the feature dialog for your feature is open though. Once the user presses the green check mark, the red will go away and the edge will be black again.
