Documents and Folders
adrian_traceadrian_trace Member Posts: 5
I have made a horrible mistake!!
I have a directory structure what consists of folders at the top and the bottom levels.
In the middle there is a document. (Made in error).
I cant move the folders out of this document and so it is not organised as I would like. Also a side effect is that the version control is shared across folders. :-(
Is there any solution to this problem please?
  • kevin_guokevin_guo Onshape Employees Posts: 18 image
    Adrian,
    Please open a support ticket with the proper information, Onshape team can help you out.
    Kevin
