qParallelPlanes
papawo
Member, Developers Posts: 206 PRO
How to use qParallelPlanes ?
Will it give me plane/face of the part parallel to the ref plane selected?
Jake_Rosenfeld
@papawo
qParallelPlanes is a filtering function:
https://cad.onshape.com/FsDoc/library.html#qParallelPlanes-Query-Plane-boolean
It filters out all the faces of `subquery` that are not parallel to the reference plane. `subquery` should be a query that resolves to some number of faces that you want to filter down.Jake Rosenfeld - Modeling Team2
You can take a look at this example https://cad.onshape.com/documents/eea009fcf35a0cd683265767/v/107cf4854dc70cbeed63cc98/e/bcd29e4ce588a4a8309e55cb
I dont understand.. can I make a copy of this document?
