Remove the selection with spacebar
emagdalenaC2i
Member, Developers, Channel partner Posts: 861 ✭✭✭✭✭
Just in case you do not know this option ...
To remove the selection in a feature, for example in the Hole feature, you can delete the selected points one by one.
But you may not know that to remove all the points selected you can press the spacebar in that box ;-)
Un saludo,
4
