array parameter - how to use
papawo
Member, Developers Posts: 206 PRO
Optionskevin_o_toole_1 Onshape Employees, Developers, HDM Posts: 565Documentation for array parameters is here.
Examples of array parameters used in Onshape standard features include fill, loft, and (variable radius) fillet. The code for them can be found in our standard library, respectively in fillSurface.fs (line 64), loft.fs (lines 88, 102, 137) and fillet.fs (line 87).6
