PLANE_OFFSET_BOUNDS
lana Onshape Employees Posts: 736
You can replicate the loopfor (var selection in definition.selFace )
within the body of the function. Then selection.myLength will be length value as you need it,
or you can doif (size(<span>definition.selFace) > 0)<br>{<br>... </span>definition.selFace[0].myLength ..<span><br>}</span>
If you are only interested in the first element.
6
It may also be that what you're passing in is not a length, or that you're not passing in an 'offset' at all. Screenshotting more of the call stack, or the line that the error is complaining on may be more useful for debugging.
You can try using something like "offset" : 0.01 * meter
"offset" : selection.myLength //<<<<<it should be this. but it doesnt work . selection.myLength is inside an array in the precondition
if I use-----> "offset" : 0.01 * meter , it does work, but I need to get the length from the precondition
May be it should be ? Not sure what you meant by "selection.myLength is inside an array in the precondition"
within the body of the function. Then selection.myLength will be length value as you need it,or you can do
