PLANE_OFFSET_BOUNDS
papawopapawo Member, Developers Posts: 206 PRO
can somebody explain why I am getting this error?
    Whatever you're passing in as 'offset' is not a length between 0 and 500 meters:
    It may also be that what you're passing in is not a length, or that you're not passing in an 'offset' at all.  Screenshotting more of the call stack, or the line that the error is complaining on may be more useful for debugging.
  • lanalana Onshape Employees Posts: 746 image
    This probably comes from a call  to cPlane either without specifying offset, or giving it a value, which is not a length.
    You can try using something like  "offset" : 0.01 * meter
  • papawopapawo Member, Developers Posts: 206 PRO
      cPlane(context, id + i + "cPlane1", {
                            "entities" : qUnion([ planeOffset]),
                            "cplaneType" : CPlaneType.OFFSET,
                             "offset" : definition.myLength, //----------sorry my mistake , definition.myLength doesnt exist
                             "offset" : selection.myLength //<<<<<it should be this. but it doesnt work . selection.myLength is inside an array in the precondition
    if I use-----> "offset" : 0.01 * meter , it does work, but I need to get the length from the precondition
    Could you post the part of your precondition where selection is defined?
    edited May 2018
    please try putting
    println("myLength" ~&nbsp;selection.myLength);
    before this call.
    May be it should be
    definition.<arrayParameterName>.[0].selection.myLength&nbsp;
     ? Not sure what you meant by  "selection.myLength is inside an array in the precondition"
    it says variable selection not found
    Probably needs to be accessed via definition
     if (definition.faceToMove)
                annotation { "Name" : "Select Face  ",
                            "Item name" : "Face",
                            "Driven query" : "entities",
                            "Item label template" : "#entities - ( #myLength )" }
                definition.selFace  is array;
                for (var selection in definition.selFace )
                    annotation { "Name" : "Select Face To Offset",
                                "Filter" : ModifiableEntityOnly.YES && ((EntityType.FACE && ConstructionObject.NO) || (EntityType.BODY && BodyType.SOLID)),
                                "UIHint" : "ALWAYS_HIDDEN" }
                    selection.entities is Query;
                    annotation { "Name" : "Offset Length" }
                    isLength( selection.myLength, PLANE_OFFSET_BOUNDS);    //how to access this?
