Fundamentals: Lesson 3, Exercise Step, Slide 14.
gerald_comeau
Member Posts: 61 ✭✭
I changed display style to Hidden Lines Visible as noted in Slide 14. I successfully completed the goal indicated in the slide but now I can't get out of Hidden Lines Visible mode. ....suggestions?
gerald_comeau
Member Posts: 61 ✭✭
I got out of Hidden Lines Visible by closing the document and then re-opening it. It is not a big problem but maybe there's an easier way.0 -
bruce_williams
Member, Developers Posts: 842 EDU
@gerald_comeau
you can switch between the various view modes. For example if Hidden Lines Visible choose Shaded or Translucent or any of other one. One view mode can be active at a time
www.accuratepattern.com8
