Configuratons - howto bind ONE table entry to TWO features
wolfgang_maier
Member Posts: 39 ✭✭✭
Hello,
assume a configuration with a table entry used in a sketch.
Howto use the same value in a second (different) sketch.
E.G. the same length is used in different sketches.
Of course i can use a configuration variable und reuse it in different sketches.
But with tables?
regards
Wolfgang
ilya_baran
Onshape Employees, Developers, HDM Posts: 1,255
You can create a regular variable (i.e., not a configuration variable), use it in both sketches, and then configure the value of the variable using a table.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc6
