How to create locking features on a split part?
in General
I create a ring shaped part and split it in the plane of the rotation. Now I have two parts (A&B) with identical mating surfaces.
Next I want to create a torus shape (2 in fact one with slightly larger cross section) central and along the line of the original rotation.
Now add one of the torus shapes onto part A, subtract the other from part B to form a circular positional interlock between the parts, once 3D printed.
Sounds good but how do I go about it? I can create the elements but cannot seem to be able to select them for the Boolean operations. Is there a better way to achieve the same effect.
My apologies in case this question has already been asked but I did not know how to phrase search criteria for this condition.
https://cad.onshape.com/documents/9797405c8d956c0cd65b7481/w/33629487f4030b9acfc9d77d/e/a07d7bb8263a2823b571c34d
Your approach seems fine, I think you are having trouble selecting for Boolean because the "larger ring" feature is set to "Surface" rather than "Solid". You can see in the parts list that one of your rinds is a surface and one is a solid. Once you go and change that, you can do one Boolean with "Union" and one with "Subtraction" as desired.
Since the large parts obscure the rings, you can make the selection by either hiding the large parts, selecting from the parts list rather than the graphics area, or by using select other from the right click menu.
Created a 'new' revolve instead of 'add' and that part was easily Boolean subtracted from Part 1 (or 2 can't remember).
Seems a bit easier and straight forward to 'add' one revolve and 'remove' the other and skip boolean altogether but nice to see both methods.
You're right that it's easier to just use the "Add" and "Remove" options directly in the revolve. I overlooked this in my answer.
You'll notice that Boolean Subtract has an "Offset" option:
You'll probably want to leave "Offset all" off and use the face of the torus as "faces to offset"
Good catch Sir.
The parts list is at the bottom of the Feature List. It may be hiding at the very bottom and need to be "slid up" by grabbing the bar above it.
You may be interested in our "Onshape fundamentals" courses. The first one goes over the user interface and points out all the little details like where to find the Parts List:
https://learn.onshape.com/collections/onshape-fundamentals-cad
If you still can't find the parts list, please post a screenshot of what you are seeing. It's a big problem with our UI if it's not showing up!
If you do a revolve with "Add", you should be able to subtract the combined part from the other part with offset just fine (as long as you specify just the toroidal face as the face to offset). There should be no need to keep the original tool around. Here's an example:
https://cad.onshape.com/documents/a984d23c132ec4ba23f27b3c/w/5be352b24d07178c6346e054/e/46d66dc736deae21a5bb175f
