Group variables into folders
dejan_pavicevic
Member Posts: 8 ✭
in General
Very often in the sketches with many parts I use variables that relate to different parts. Variables have a lot and complicate the look of the screen. Is it possible to group variables into folders to simplify the sketch?
OptionsemagdalenaC2i Member, Developers, Channel partner Posts: 860 ✭✭✭✭✭I'm not sure I understand your question well... If you are asking for group variable features into folders: At the moment it is not possible to group features in folders
But I have doubts about your comments "sketches with many parts" and "Variables have a lot and complicate the look of the screen"... You should use sketches as simple as you can, and as many sketches as you need.
That said, you can use filters...
and even rename the features
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común9
You can vote on this improvement request if you would like to see feature folders implemented:
https://forum.onshape.com/discussion/1842/feature-tree-folders#latest
