Setting equal curve lengths
Hello. I'd like to set the curve length of an arc equal to a straight line in a sketch, but can't seem to do it with the equality constraint. Is there a simple way to apply this relationship so that it updates automatically as one of the curves is modified? Thanks.
    @philip_thomas
    Effective but esoteric.  Is that why you have the 'visit Onshape' tab so we can get an explanation?  :wink:
    www.accuratepattern.com
    Lol - fair enough! :)
    The challenge is that 'length' and 'arc length' are two different things.
    If i said, make this line and this arc 'equal' - what am i setting to be equal? The length? The Radius?
    This solution uses a custom feature that allows me to measure something and assign the measured value to a variable. Once a variable exists, i can use it in any other sketch or feature (but not the same one).
    By sharing the document, the user now has access to the custom feature :)
    Philip Thomas - Onshape
    Excellent - glad you splained.  Passing on the Custom Feature is good and I had not even thought of the ambiguity.
  • JaimeeowJaimeeow Member Posts: 10 ✭✭
    how did you make the custom feature from scratch? i'm so confused. there's two part studios? and the second part studio is just referencing the first part studio??? :dizzy:
  • S1monS1mon Member Posts: 3,777 PRO
    edited February 2023
    This is an old thread. You can create a variable on the fly in a sketch and use it to dimension both the linear and arc lengths. You can start typing '#' for a dimension and you can create a new variable. Once you do that, enter that as the dimension for the other entity. Here's a very simple part studio with the sketch.
    Note: you still can't dimension the length of a spline, conic or path in sketcher, just individual arcs and lines. See this improvement ticket.
