Exclude a segment from bending
Henk_de_Vlaam
Member, Developers Posts: 267 ✭✭✭
Before I request an improvement I like to ask first if it is possibility to exclude segments of a bending line from bending? As you can see in the picture I made a sketch in the flat state that creates an interrupted bending line. I like to exclude one segment of bending.
As a workaround I tried also to add a Tab. Then surface A should be coincident with bending line B before adding the tab. However, I think I found a bug (and reported this) ==> the cut does not extrude when A is coincident with B.
You can not exclude a part of a bend from bending. Thank you for reporting a bug - we'll look into it. This should work if you cut into the wall (a little past
https://forum.onshape.com/discussion/9606/exclude-a-part-of-a-bend-from-bending/p1?new=1
