Exclude a segment from bending
Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 249 ✭✭✭
edited June 2018 in Community Support
Before I request an improvement I like to ask first if it is possibility to exclude segments of a bending line from bending? As you can see in the picture I made a sketch in the flat state that creates an interrupted  bending line. I like to exclude one segment of bending.
As a workaround I tried also to add a Tab. Then surface A should be coincident with bending line B before adding the tab. However, I think I found a bug (and reported this) ==> the cut does not extrude when A is coincident with B.
Henk de Vlaam (NL)
