2 loft guides with same origin?
samantak_mitra
Member Posts: 1 ✭
Is there any way to make a loft follow 2 curves with the same origin? What would be an other way to do this?
https://cad.onshape.com/documents/b192ac1367efe42bf4fde025/w/414c94fa6e80ccc04cb236bb/e/427dc12044e31ae916672606
OptionsemagdalenaC2i Member, Developers, Channel partner Posts: 861 ✭✭✭✭✭There are a lot of issues in the model, most of them because the points don't match exactly in the position where they should be
Also, you should try to do it simplier
I try to simplify and order a bit the part studio here
https://cad.onshape.com/documents/38d35f5ba432baf7755d993e/w/1059153fe4ec1f3c51f603b1/e/1ac3a1c0c3d3841a3c5bebc1
As you can see, you can create a loft that follow 2 curves (or more) with the same origin
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común4
