Support for Silhouette Edges?
Don_Van_Zile
Member Posts: 195 PRO
in General
Is there any plans to support inference and/or relations to silhouette edges of holes/cylinders (revolved geometry) automatically within a sketch without the need for in the "Intersection" command added to the workflow? I find I need to reference to silhouette edges quite often enough to justify it automatically upon selection.
Also, not sure if it's a direct result of or an anomaly, but only some silhouette edges show up as they should in views such as shown in the pic below (the opposite edge of the hole's don't show).
https://cad.onshape.com/documents/2ce8e8e2034a25907269e575/w/d5f25bbec75833f1a237b1c9/e/3c2b271c56634f6af0eb24ad
OptionsMBartlett21 Member, OS Professional, Developers Posts: 2,034 EDU@Don_Van_Zile
Intersection only shows where the face 'hits' the sketch face.
Use can get you the ends and the sillhouette edges5
