Can I create my own standard content?
ethan_keller924
Member, csevp Posts: 40 EDU
I've got some custom pipes and pipe fittings I would like to insert into an assembly. I can easily do this with configurations, even across documents (thank you, OnShape!) But I was wondering if there is any way to create my own standard content that could be owned and organized by a team? This seems like a common use case. Right now I just use a "shared" document that teammates can pull parts from. Is this the recommended way to do this ATM? and are there any plans to incorporate shared content functionality?
This tab have
"* Utility functions for internal development Onshape Standard Content.
You can check if there are some way to do that... But "These functions are not yet intended for general use", so maybe in the future Onshape will add the option to create custom standard content ;-)
