Can't select the right axis for my circular pattern in assembly
yab_mas
Member Posts: 2 ✭
Hi,
Beginner here and first question on the forum, hope I give enough info.
I'm trying to use circular pattern in my assembly, I simply want the middle to be the axis but it won't let me select a face, just edges.
I'm sure there is a simple solution, I just don't seem to be able to figure it out.
https://cad.onshape.com/documents/dfbb1352d76a8efdb48839a7/w/4063ed35338c2cbe0612636d/e/c8e35194e62e6de2cc23215a
jackson_king
OS Professional Posts: 80 PRO
Create a mate connector in the center of the square gray plate. Use that for your circular pattern5
