What's wrong with my pack and go zip file?
daniel_stevenson897
Member Posts: 3 ✭
Just learning Onshape and this is likely an operator error, but help would be appreciated. I'm attempting to upload some Solidworks assemblies. As per the dialogue box, I did a pack and go from SW to a zip file. When Uploading the file I get the error message, "Zip translation not supported batt.zip was not translated. The zip did not contain any recognizable files." I've tried this with a couple of different files. Also tried uploading the assembly doc directly, including the parts and assembly files. The parts uploaded, but the assembly doc was not. The error message indicated that the file was untranslatable. One of the the offending files is attached in zip format.
daniel_stevenson897
Member Posts: 3 ✭
Hum, I'm using the zip option from SW pack and go dialog box. The only option used there is "flatten to a single folder". I'm not using a separate zip utility after pack and go. I'd assumed that SW uses it's own zip implementation, not another application. What zip utility did you use? The image from your link is an accurate conversion of the original SW files.0
UX/PD/Community Support
https://cad.onshape.com/documents/7d5e0d486d6261e1b41ee8ad/w/d101638aa9976224a5453fea/e/a274184de11b3f4afbdba57e
