Extrude Feature will not allow a second extrude
max_poelmann
Member Posts: 2 ✭
Currently working through the self paced course, and am trying to make a second extrude on a sketch, but onshape won't allow, any tips why?
In your Extrude feature, you have Add selected. Since there is nothing selected in the Merge scope, you will see this feature become errored. (If you hover over the errored feature, you can see a tooltip with some clues about the error.) You will need to change this to New.
