How do you make a revision of a configured part?
Brian_GoldsmithBrian_Goldsmith Member Posts: 7 ✭✭
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    @Brian_Goldsmith are you looking to make a revision of the entire configuration or just one configuration instance of the part? Also, are you doing this manually in Onshape or using the release workflow?
    Twitter: @bradleysauln
