Missing constraints drop down while in sketch mode
robert_richrobert_rich Member Posts: 7 EDU
I noticed in Cody's Tech Tip: Pre-select Constraints while Sketching in Onshape of Aug 28th, his tool bar shows a drop down with all of the constraints grouped together with text labels. I'm not seeing this in my user interface. All my constraints are stretched out on the tool bar. Has that feature not yet been pushed out yet or ...?
Link to the Tech Tip is:
https://www.onshape.com/cad-blog/tech-tip-pre-select-constraints-while-sketching-in-onshape?utm_source=hs_email&utm_medium=email&utm_content=65517846&_hsenc=p2ANqtz-9WGC-e-N10QMRRxCsaZ5VrguIrzTSDNAUBCRXX7J59HTMSq4xKbjMDEb83yjilShjhzHTdoZocPoF85wzHVqE-Yxgw4RKEXoEZf5c-XA39ttCsOZE&_hsmi=65517846
  • robert_richrobert_rich Member Posts: 7 EDU
    Ok, I now see that this question was just answered by Gaby: "This is dependent on your browser window size. If it is a smaller window, the constraints will be compressed into a dropdown." Thanks.
    @robert_rich
    It may help to note that all of the toolbar buttons have tooltips, so if you're confused about what the icon is representing you can just hover over the button and it will tell you what it does.
