Circular duplicate does not finish
tonvistonvis Member Posts: 41 ✭✭
Please help with following failure message
System hangs,
Onshape encountered a problem with your last operation. If the problem persists, please contact support. Support code f73e4a10f6abde5491478cb3.
Have difficulties to submit a screenview
Thanks for any help
Regards
Tonvis
    @tonvis
    It seems that your circular pattern is working now.  Are you still having trouble?
    In general we don't advise modeling cosmetic features like this, unless you plan on 3d printing your part.  Otherwise they add a lot of unnecessary graphical complexity to the part studio with mostly no modeling benefit.
  • tonvistonvis Member Posts: 41 ✭✭
    Thanks Jake,
    Problem solved
    I found my way around
    steps:
    1 -  making the extruded part ,
    2-  camfer both sides,
    3-  helix  with sketch of pattern,
    4-  mirror the item,
    5-  circular duplicate (remove) the patterns,
    this will finish without difficulties,
    After that adding the rest of the part.
    Regards Ton
