Assembly Issue (Edit Solved): The "Reorient secondary axis" Button Doesn't Work...
Don_Van_ZileDon_Van_Zile Member Posts: 195 PRO
edited September 2018 in General
The "Reorient secondary axis" button functionality doesn't work for the first Mate Connector selection; it doesn't advance the mate connector in the graphics area. It does for the second Mate Connector selection. I'm fairly certain I was able to do this.  Anyone else have an issue?
I can't get my Pin Slot Mate to work the way I need it to...
EDIT: Please disregard as my first mate connector was an actual Implicit Mate connector which can be edited itself separately. The "Secondary" verbiage should've been the give away.
