Use of variable for number of sides
Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 256 ✭✭✭
edited September 2018 in Community Support
I like to configure the number of sides of an inscribed polygon. I tried it with a configuration variable which is not accepted with me. I also made a variable feature which also did not succeed.
Is this impossible or am I doing something wrong? Or is there another way to steer this value other then selecting the red boxed value.
Henk de Vlaam (NL)
    i beleve you can't do it in sketch, just like with sketch patterns. If you need to parametrize polygon I'd use 3d pattern feature
