Am I being obtuse, or has the Measure tool been removed?
I'm sure I used it when I first started using OnShape.  I can't find it anymore.  The help files say it should be at the right end of the bottom of the screen, but there's nothing there.   Is it only on certain screens?  I want to measure some hole diameters on an assembly without going back and editing the sketches.  Thanks.
  • RChilcoat
    RChilcoat Posts: 12
    Thanks everyone.  The help files show a little icon that looks like a pair of dividers, and that was what I kept looking for.  I didn't think to just select something on the assembly.  Works great.  Now back to work.
  • RChilcoat
    RChilcoat Posts: 12
  • john_mcclary
    john_mcclary Posts: 4,095 PRO
    @RChilcoat
    Please vote on this IR if you believe this would have prevented this
    https://forum.onshape.com/discussion/10216/visual-aid-for-measure-calculation/p1?new=1
  • The help files should be updated to reflect this change. Measuring is now automatic and doesn't require selecting a tool. I got stuck searching for the none existing tool that is described in the help.
